Hoping for some help. I'm new to the Fitbit Blaze. Before going for a run, I'd usually preset my distance so I know how far I have left to go, when I'm at halfway mark etc. Is it possible to do this with the Fitbit Blaze? Thanks
Best AnswerIt is not possible to do exactly that... However, if you have running cues turned on for distance, if for example, you want to to go 8 km, you can turn around when you get the 4 km cue.
Alternatively, you may like to add this idea to the feature request board. Important tip: always do a search first to see if your request, or a similar one, has already been proposed.
03-12-2017
05:56
08:26
03-12-2017
05:56
08:26
A warm welcome to the Forums @KMRunner and @Julia_G thanks for stopping by.
As our friend mentioned, there is not an option to do this. I took the liberty and searched for a request like this but didn't find any, so please visit our feature suggestions board and share your ideas.
Catch you later. ![]()
