12-19-2018
18:22
16:07
FerdinandFitbit
12-19-2018
18:22
16:07
FerdinandFitbit
Well, once again, for several weeks, my Blaze syncs with my phone, but either never gets the gps signal (red signal strength bars) or finds it for a while (green bars) then liises it within seconds or minutes. I have reset both phone and blaze repeatedly to no avail. Anyone know a solution to this?
Moderator edit: Updated title for clarity
Best Answer12-20-2018 16:05
12-20-2018 16:05
Hi there @KurtH, welcome to the Fitbit Community Forums! 🙂
I'm very sorry to hear that your Fitbit Blaze is not connecting to the GPS correctly. Thanks a lot for all that you've tried to get it to work. I'd like to help you out.
A weak GPS signal on your mobile device is often caused by environmental factors such as tall buildings, dense forest, steep hills, or even thick cloud cover. All of these can interrupt the connection between your tracker and GPS satellites.
To make sure that GPS will work well, make sure that you meet the following requirements:
Hope this helps. Let me know if you need more help!
