Hi all. I use my Blaze a little over 120 days a year. I'm a fire fighter, so I work 24 hr on, 48 hr off. This is my second Blaze. Both can't make it through a year without malfunction. Both stopped working with the heart rate feature. Both wouldn't take a charge after a year.
Is there a FB that can take a beating and still work? I'm tempted to give up and just use my Walmart watch I bought 5 years ago that still works fine. Ideas? Thanks!
First thing how are you charging it?
See this thread for charging best practices. If you are not charging it correctly you could be damaging the battery
Maybe try one of the smaller ones like the charge series. This will fit under the sleeve better and have a bit of protection.
Wendy | CA | Moto G6 Android
