08-27-2017 00:51
08-27-2017 00:51
I can't get my blaze to sync to either the relax mode or the Fitstar mode. I've tried syncing it a ton of times but it just keep telling me "sync your blood is in the Fitbit app to get fit star workouts on your wrist" or " sync your blaze and the fit bit app to get relaxation exercises on your wrist". I've tried syncing it normally where you pull down the screen in the app but that's all. Am I missing a step? Do I have to go into a certain setting?
05:22
03:38
08-28-2017
05:22
03:38
Welcome to the Community Forums @Shannonshiv! 🙂
When it comes to FitStar workouts and the Relax feature, they should already be on your Fitbit Blaze. Now, Relax will not sync anything to your Fitbit dashboard. It will only guide you through a breathing session of either 2 or 5 minutes (depending on which one you choose) and FitStar will not add more exercises than the three that already came with your tracker.
Please let me know if this is what you're referring to or if I'm missing something. I'll be happy to further help!
10-18-2017 12:16
10-18-2017 12:16
That isn't exactly what she is referring to. I am having the same issue with my Blaze. Regardless of how many times I sync the Blaze with my phone, the Relax setting will not be operable on my Blaze. It only gives the "sync your blaze and the fit bit app to get relaxation exercises on your wrist" message. I understand that Relax will not give any information on the Dashboard. The other odd thing is that the FitStar was having this issue and then all of the sudden the 3 exercises showed up on my Blaze. Still nothing from Relax however. And yes my Blaze is updated to the latest version 17.8.401.3 and I am using the "Sync Now" function to sync my Blaze.
Best Answer01-07-2018 04:18
01-07-2018 04:18
I am having the exact same issue.
It it was working before the update.
Best Answer01-07-2018 04:21
01-07-2018 04:21
@petermblack wrote:That isn't exactly what she is referring to. I am having the same issue with my Blaze. Regardless of how many times I sync the Blaze with my phone, the Relax setting will not be operable on my Blaze. It only gives the "sync your blaze and the fit bit app to get relaxation exercises on your wrist" message. I understand that Relax will not give any information on the Dashboard. The other odd thing is that the FitStar was having this issue and then all of the sudden the 3 exercises showed up on my Blaze. Still nothing from Relax however. And yes my Blaze is updated to the latest version 17.8.401.3 and I am using the "Sync Now" function to sync my Blaze.
