05-08-2017 09:14
05-08-2017 09:14
Hi Community!
First of all I would like to say that I love Fitbit. The way their device & app work are superb, and for this reason I do not wish to switch to another brand.
But...
I have owned my Charge 2 since January this year, and the wristband has already been replaced twice. The support from Fitbit is great, but I don't feel like replacing the wristband every 2 months.. So yeah I could just get an aftermarket wristband, but no, I am too stubborn.
The main things I use my Fitbit for are step recording, heartrate and sleep (+ silent alarm).
Is it worth it to change to a Blaze? I am not sure if this will be an upgrade or downgrade.. And there is no point in waiting for a new release since Fitbit has not even announced anything.
Best Answer05-08-2017 09:28
05-08-2017 09:28
I don't have a Blaze so I cannot answer it that directly, however seeing what you want out of a tracker did you also consider the Alta HR?
On this page you can compare all the different trackers available.
Karolien | The Netherlands
Best Answer05-14-2017 04:33
05-14-2017 04:33
It's great to see you around @Monster696 and @Esya thanks for stopping by.
I recommend checking the following chart, there you will be able to compare the features that each tracker have.
You can also take a look at our compare page to take a look at all of our trackers.
See you later. ![]()
