03-12-2017
12:42
19:05
DavideFitbit
03-12-2017
12:42
19:05
DavideFitbit
How do i reset the time on my fitbit after the battery went low
Moderator edit: format
Best Answer03-12-2017 12:48
03-12-2017 12:48
The time will be set correctly during the next sync, so open the app up.
Best Answer03-12-2017 12:59
03-12-2017 12:59
Best Answer03-12-2017 14:44
03-12-2017 14:44
@DonChamberlain wrote:
How often do the sync happen?
That would depend on what device(s) that you sync through and your settings.?
The computer use to be every 20 minutes, but I think it is 60 now.
On the phone if all day sync is off, it will sync when turning on the app.
With all day sync on it is every 60 minutes and when the app is open
