05-23-2016 10:42
05-23-2016 10:42
On a typical day I burn about 2100-2300 calories. Today I woke up and my fitbit blaze was showing over 3k calories burned for the day, which is obviously not the case. I've tried updating, syncing, removing the device from my dashboard and holding the left and bottom right button to reset. It's still showing almost 4k calories burned for today. Any suggestions on how to correct this?
Everything else looks good. I'm at about 600 steps for the day and heartrate is normal.
Best Answer05-24-2016 07:30
05-24-2016 07:30
@pinkjilly wrote:On a typical day I burn about 2100-2300 calories. Today I woke up and my fitbit blaze was showing over 3k calories burned for the day, which is obviously not the case. I've tried updating, syncing, removing the device from my dashboard and holding the left and bottom right button to reset. It's still showing almost 4k calories burned for today. Any suggestions on how to correct this?
@pinkjillyJust in case you weren't aware, check this out. If you didn't already know, the Blaze will take into account your information and your Basal Metabolic Rate (BMR), which is the rate at which your body burns calories by simply keeping your body functioning. Obviously, on top of that it will go on actual activity you undergo.
