My silent alarm is no longer helpful. I was using it all the time but the most recent update has changed the alarm so that it only vibrates 3 times and then stops. Before it would vibrate for up to 1minute and you had to turn the alarm off or snooze it for the vibrating to stop. That to me makes more sense. I have not been waking up to just the three vibrations and was thus under the impression it was not even working. Please fix this and restore former vibration function Fitbit!
Mine only vibrates twice and then does not vibrate again even if I dont shut it off.
Im not sure if it changed after the update.
But you can go vote for it here and maybe they will bring it back
Wendy | CA | Moto G6 Android
It's great to see you around @ksousa07 and @WendyB thanks for stopping by.
It's weird to hear that your Blaze is just vibrating 3 times, are these long or short vibrations? Have you tried to restart your Blaze? If you haven't, I recommend following our restart procedure.
Hope to hear from you soon. ![]()
