05-02-2016 14:05
05-02-2016 14:05
07-20-2016 03:44
07-20-2016 03:44
05-02-2016 14:26
05-02-2016 14:26
05-02-2016 16:28
05-02-2016 16:28
05-02-2016 16:29
05-02-2016 16:29
@Vinnysfitbiy Welcome to the Community! I would like you to confirm that you're doing this settin up alarms procedure posted by @SteveH.
Also, please provide me with more details about the issue that you're experiencing. Are the alarms vibrating or are they not vibrating enough?
Keep me posted.
Best Answer05-02-2016 17:07
05-02-2016 17:07
05-03-2016 04:39
05-03-2016 04:39
My blaze does vibrate enough to wake me up, but whether the alarm works at all is very hit and miss, some days it works and some days it doesn't.
I have even been awake sometimes when my alarm is supposed to go off but the alarm hasn't worked, so it's not that I'm sleeping through it.
To start with I thought that the blaze was clever enough to recognise that I was already awake and cancel the alarm, can you confirm if this is the case?
Thanks
Graham
05-03-2016 06:19
05-03-2016 06:19
Thanks
Graham
Same here.
Best Answer05-09-2016 10:28
05-09-2016 10:28
@Vinnysfitbiy Thanks for the details! I just tested the alarm on my Blaze and I believe the reason why it may not be vibrating enough it's because you're wearing it too loose.
However, you may want to vote for this idea because those suggestions are viewed by our engineers.
@SunsetRunner @robguitar A warm welcome to the Community! Blaze will not recognize you're awake and turn off the alarm, you need to check the display and let the tracker know you already awake. You may want to post this idea in our Ideas Board because people can vote for them.
Regarding the alarm that vibrate sometimes, can you give me more details about it? Do you have to set it up everyday? Have you tried restarting the tracker?
Hope this helps.
Best Answer05-09-2016 10:41
05-09-2016 10:41
@SilviaFitbit wrote:Thanks for the details! I just tested the alarm on my Blaze and I believe the reason why it may not be vibrating enough it's because you're wearing it too loose.
Any tighter it'll cut off blood flow to the hand or the strap will break. The problem is not with how the Blaze is worn, the problem is with how it was designed.
05-17-2016 14:01
05-17-2016 14:01
05-17-2016 15:50
05-17-2016 15:50
Easy and simple fix would be to have the vibration only stop if the wearer clicks the top right button on the blaze, for example.
06-06-2016 23:25
06-06-2016 23:25
07-18-2016 18:19
07-18-2016 18:19
Yep - I had the same issues with the weak silent alarm and sent my blaze back after a couple of days. Back to the HR for me...
Best Answer07-19-2016 12:24
07-19-2016 12:24
Best Answer07-20-2016 03:44
07-20-2016 03:44
01-05-2017 08:47
01-05-2017 08:47
I've set my up and with the resent update they aren't working period now.
Best Answer04-05-2017 21:06 - edited 04-05-2017 21:09
they are too week. i can barely feel it. my charge HR worked great. it woke me up every time it went off. now with the blaze, i sleep through it. i have to wear my charge HR just for the alarm. if i don't get this fixed soon, i am taking it back. its a BIG waste of money!!! i just bought mine. it looks like its almost been a year and they still have not fixed the problem!!!! GRRRRR!!!!!
Best Answer04-06-2017 17:17
04-06-2017 17:17
Welcome to the Community @CYeadon! Fitbit truly appreciates your feedback; we have our Feature Suggestion board, where you can vote or comment in the ideas that are already posted. As mentioned before, these are viewed by our engineers and developers.
Once again thanks for supporting the idea. Fitbit is always trying to improve its trackers and website.
Best Answer04-12-2017 10:24
04-12-2017 10:24
you put
@SilviaFitbit wrote:Welcome to the Community @CYeadon! Fitbit truly appreciates your feedback; we have our Feature Suggestion board, where you can vote or comment in the ideas that are already posted. As mentioned before, these are viewed by our engineers and developers.
. they might view them, but they have done nothing to fix the problem. this post has been up for almost a year and the watch still has the same problem. i rely on the silent alarm to wake me up to go to work in the morning. i used my fitbit charge HR for almost 2 years until the band broke. i wish i could just replace the band on that one.now i have to wear that one to bed and then change watches in the morning. i did not pay over 230$ to have to do that. it looks like i will be returning it and getting a different watch and maybe a different brand. . i spoke highly of your products to my friends and coworkers. i think that is going to change now.
Best Answer04-13-2017 12:45 - edited 04-27-2017 16:32
Thank you so much for your comments @CYeadon! I'm sorry to hear that you feel this way, the Feature Suggestion board is there for the engineers to get ideas of what users want.Currently, I can't confirm all of them will be implemented or provide you with an specific time frame about it.
Once again, Fitbit is always trying to improve Fitbit trackers and website.
