Silent alarm vibration too weak
I've recently upgraded from an HR to the Blaze & find the vibrations on the silent alarm too weak. I've already over slept once and have had to revert to an audible alarm clock once again for my 0445 get up. Anyone else experiencing this. Perhaps something that can be improved via an update
4 REPLIES 4
It's great to see you around @Fulham28. If the vibration of the Blaze is too weak, I recommend restarting your tracker. Keep in mind that there isn't an option to customize this but I recommend checking the Make Blaze vibration stronger request, vote for it and leave your comment.
Catch you later. Woman Wink
Agreed, coming from a Charge, the vibration on the Blaze is a lot weaker.
Thanks @AlejandraFitbit for the link, I've voted for it.
You are welcome @wGlenn and I hope this can be implemented soon, it would be great to customize the Blaze's vibration.
Happy stepping! Woman Wink
This is the first negative review i have ever written. I received the Blaze yesterday and I disappointed. The alarm is VERY weak. My previous Fitbits were great. The community shows this as a major issue, but when I called tech support the women I talked to told me didn't see the problem in their database. I reset it per her advice to no avail. Back to my Charge HR. Sending back to Amazon.
