09-11-2017 16:07
09-11-2017 16:07
Hi since Aug 21st my Blaze no longer records my sleep or any active minutes. I work out 3-4 time a week and showing 0 active minutes every day. What can I do?
09-12-2017
07:33
11:47
09-12-2017
07:33
11:47
Hi there @SunsetRunner. Great to see you in the Community Forums!
I'm sorry you're having problems with your sleep and active minutes not showing up on your dashboard 😕 We were having some issues with sleep not appearing correctly so this might be the reason why.
In the meantime, I can suggest restarting your tracker if you haven't done this. You can easily do this by pressing the left and lower right buttons for 10-12 seconds. This will make your tracker to reboot.
Also, if instead of sleep stages you're seeing the old sleep patterns (which shows your time asleep, restless, and awake), there are a few scenarios where this will happen:
Hope this helps. Let me know if you need more help with this!
09-12-2017 08:18
09-12-2017 08:18
My Blaze did noting last night after I thought it was finally fixed. Wasn't too tight or loose. Everything same as always. Rebooted it this morning. But then I did that the last time. Hoping it works tonight.
09-12-2017 09:18
09-12-2017 09:18
I noticed the same thing happening to me after August 25th, no sleep data at all. Reset the blaze this morning, hopefully it will be fixed tonight.
09-13-2017
12:48
11:47
09-13-2017
12:48
11:47
Hey guys @Stampy1824 @Wynston, great to see you in the Forums! 🙂
Please try that out and let me know how it goes!
09-14-2017 01:53
09-14-2017 01:53
I reset my Blaze and the sleep and active minutes seem to have worked the last 2 days but my HR also hasn't worked since 21st Aug and I didn't realise this until I checked it. This however has not worked since rebooting twice. It just shows 2 dashes (--) and no figures at all!
09-14-2017 08:59
09-14-2017 08:59
No luck so far. I manually set the sensitivity to 'sensitive' for sleep tracking,shutdown and restarted the blaze, tried wearing it on the other wrist, so far nothing seems to be working to get it to auto-track sleep for me 😞
