03-29-2017
08:53
15:52
AlessFitbit
03-29-2017
08:53
15:52
AlessFitbit
I have the most up to date app and my iphone is up to date as well. Yesterday, my sleep stages tracked, but last night it did not. I've restared the Fitbit, the phone, installed, uninstalled, and reinstalled. Nothing worked. Any idea how to fix?
09-03-2017 06:21
09-03-2017 06:21
Same here - I've had my Blaze a year and a half and had a few hiccups when it went to the new sleep tracking method but the past 2 nights, consistently have been showing sleep record under the OLD method. I didn't like the new method at first but now find it incredibly helpful and fascinating just how much time I spend in Deep and REM sleep. It appears to be a widespread problem and nothing to do with individual users. Fitbit, please get this fixed FAST!!
09-03-2017 06:27 - edited 09-03-2017 06:39
Same here last two nights no sleep stages. I think its a problem on Fitbits end wish they would stop messing with whatever it is that does the sleep for us.
Correction after syncing again my sleep for last night show stages again.
09-03-2017 06:44
09-03-2017 06:44
I synced again but no luck. Do you have a Blaze?
Best Answer09-03-2017 06:46
09-03-2017 06:46
Best Answer09-03-2017 06:49
09-03-2017 06:49
Best Answer09-03-2017 06:50 - edited 09-03-2017 06:50
Pleased for you but here in the UK still have no sleep detail after syncing and re-pairing the Blaze
Best Answer09-03-2017 06:53
09-03-2017 06:53
I am in the US and having sleep tracking issues
Best Answer09-03-2017 06:54
09-03-2017 06:54
No, mine is still not showing sleep stages. It's a new problem here, too. It's just the last two nights after (for me) months of working fine with no problems.
09-03-2017 06:54
09-03-2017 06:54
I'm having the exact same issue, too. My Blaze hasn't tracked my sleep stages for the past two nights. I'm glad this isn't just me and I appreciate its being fixed!
09-03-2017 06:56
09-03-2017 06:56
Best Answer09-03-2017 07:02
09-03-2017 07:02
Yes Malcolm I guessed from your mobile number!
I think it's probably pointless continuing to post on a thread that Fitbit thinks is solved. I'm posting in the latest threads to try and keep in current.
Best Answer09-03-2017 07:04
09-03-2017 07:04
I am in New York State and my Blaze is not tracking my sleep properly
09-03-2017 07:11
09-03-2017 07:11
I have all the current updates and my sleep stages have stopped working. This was one of the main reasons I upgraded from the charge.
09-03-2017 07:15
09-03-2017 07:15
The most infuriating part to this is when FITBIT marks this issue as solved when it's proven to be an ongoing issue for them. They can roll out new $300 trackers, but can't get the basic functions of their products to work; And most importantly they do not communicate effectively to their consumers.
I had issues with the sleep trackers working intermittently and I've even gotten a 2nd blaze. None of my sleep habits have change and I know all the listed tricks & tips. It's fitbit's problem not the users.
09-03-2017
11:33
11:35
09-03-2017
11:33
11:35
I've tried every possible fix, my Blaze still does not show sleep stages.
Moderator Edit: Personal info removed
Best Answer09-03-2017 16:06
09-03-2017 16:06
Yay I had the same problem with sleep measurements. Been having for the last three days. It looks like many using the blaze is have the same or similar problems at the same time.
09-04-2017 05:38
09-04-2017 05:38
My Blaze is not tracking sleep pattern either
09-04-2017 06:40
09-04-2017 06:40
FlatRonnie, not so. Sadly I slept with my Charge 2 AND Blaze last night, so I'd for sure get Stages one way or another?
no deal!
nothing stagelike for EITHER device!!!!!
Best Answer09-04-2017 07:27
09-04-2017 07:27
I am having the same issue as well!!
09-04-2017 07:32
09-04-2017 07:32
