06-21-2016 06:11
06-21-2016 06:11
Hi there,
New to the forum. My wife and I got each other a fitbit Blaze each for our Anniversary. I can sync fine when connected to wifi but doesn't seem to work properly through bluetooth. I also can't get notifications from my phone to the blaze or use the blaze to control music.
The music control would be a nice to have, but the notifications was a big reason for getting the fitbit, I'm on call a lot if I can get my fitbit to vibrate when a call / text comes in it means I can leave my phone on silent rather than waking up my wife.
I know that the blaze needs the phone to be BT LE compatible which my phone is and it seems to work when i first set it up, but then it stops working agian.
Has anyone been able to get the blaze to work with an M4 Aqua?
Hope someone can help.
Regards
Alex
Best Answer06-21-2016 14:02
06-21-2016 14:02
May I ask what is not working.
You mention Caller I'd.
Does the Blaze Sync through the Phone, this can only happen through Bluetooth and an internet connection, both are needed. Either WiFi or cellular will work.
For Android Bluetooth classic needs to be paired for music control.
I see a hint that there might be multiple problems, syncing issues would be the first we would want to address
Best Answer06-21-2016 14:15
06-21-2016 14:15
@denimknight, as far as I can tell, your phone is not currently supported by Fitbit.
Best Answer06-21-2016 23:59
06-21-2016 23:59
07:05
10:54
08-10-2016
07:05
10:54
A warm welcome to the Community @denimknight. @Rich_Laue and @shipo thanks for stopping by and the troubleshoot provided.
I would like to know if you keep having problems with your Blaze?If you do, as mentioned before the reason why your tracker isn't connecting with your phone is because your phone is not a compatible mobile device. I recommend syncing your tracker with a computer or compatible phone and keep an eye on our list for any update.
See you around! ![]()
Best Answer08-28-2016 09:31
08-28-2016 09:31
09:10
10:49
08-30-2016
09:10
10:49
Hi there @Htun. Im happy to see you in the Community! ![]()
Thank you so much for providing all those details as they will be taken into consideration to avoid having these type of issues in the future.
See you around!
Best Answer12-04-2016 08:28
12-04-2016 08:28
Hey,
I have a M4 and have had similar issues, it syncs and things and displays messages and works perfectly for about 3 days of the week, forget about the other 4 as they are pretty much completely unuseable, it seems stupid that it works on other Xperia phones but not this one
Best Answer12-05-2016 14:15
12-05-2016 14:15
I can see why it would work on one Xpeeia phone and not another one, the hardware mught be different and the Fitbit app has not been optimized yet. It doesn't make sense that it works perfectly fine for 3 days, then fails the other 4.
I can see that a restart may be required when the app is updated.
My thought when it fails to sync, check Fitbit.com to see if it really dod fail, and if so go into the phones BT settings and tell it to forget the tracker.
Do not remove from the Fitbit app.
