After trying everything, I tried turning the bluetooth off on my Ipad that was in the same room as my Iphone used to sync the blaze. Instantly my connections problems dissappeared. This was so even though my Blaze had never been synched to my Ipad. Perhaps I missed it, but never saw this issue mentioned. Hope this helps someone!
Yes it has been mentioned before.
Thanks for the reminder! Im sure it will help someone else!
Wendy | CA | Moto G6 Android
It's great to see you around @wxman123 and thank you for mentioned the tips you did to fix your syncing inconvenience, I think it will be helpful for someone.
Keep the stepping up! ![]()
