06-10-2016 07:04
06-10-2016 07:04
Hi all.
Bought the Blaze 2 days ago. Thought this was it.
After using an epson pulsense that had some issues syncing (needed to ocasionaly turn off the bluetooth and then on), i decided to do an upgrade to a brand known by their quality.
Boy was i a fool so far.
My Blaze only syncs once. Period.Dashboard never shows heart rate.
And it only syncs partially, I can change the cloock look but it never syncs exercise selection!
After sync i need to unpair and pair again otherwise it NEVER EVER syncs....
Runing Blaze with a BQ E5 FHD with Android 4.4.2 (KitKat)...
I really love the design but it is not functional.
Can someone help?
Will a software upgrade on the Blaze solve this? Will it be soon?
I really want to believe in fitbit but i have been reading so many issues with syncing......
Thanks!
06-10-2016 07:21
06-10-2016 07:21
What is the point selling the Blaze when it wont sync to my 8.1 phone & many others given the discussion boards here - even though your own website says it will?!!! pretty annoyed.
06-10-2016 07:30
06-10-2016 07:30
It blows my F******* mind!!
I mean look at the reviews, no one who tested it saw syncing issues????
Are the reviews legitimate??
How could this pass??????????????
Everywhere i look. Tons of issues with the blaze! In the reviews - nothing!
If the wont solve. Fitbit is dead to me! This is actually slowing my progress not helping!!!
Come on fitbit work around it! Blaze is beatifull give it a chance to shine!
06-10-2016 09:54
06-10-2016 09:54
I have been having problems with the syncing since Friday 6/3/16, I am constently shutdown my Blaze as well turning my phone on an off this is becoming very annoying is there a fix for this issue yet. I am about ready to return this and get my money back if this continues to happen.
06-13-2016 08:37
06-13-2016 08:37
Hi everyone! I'm glad to see you all in the Community!
I would recommend that if your trackers are not syncing, you can try to do a restart on them. For this, just press and hold the left and lower right buttons for about 10-15 seconds and this will make the tracker to turn off and back on. It could also be worth restarting your phone and then try to get it to sync and see how it goes.
Anything else you may need, let me know! 🙂
06-14-2016 12:21
06-14-2016 12:21
06-15-2016 08:48
06-15-2016 08:48
06-15-2016 08:52
06-15-2016 08:52
06-15-2016 17:10
06-15-2016 17:10
Ok - I am going to call it. The Blaze just dosen't work, It wont Sync. Sick of restarting phone, App, Blaze, reinstalling app. The manufacturers need to fix this ASAP. I would hate to recommend it as garbage to potential new users, but that's coming soon.
06-15-2016 18:47
06-15-2016 18:47
06-15-2016 21:51
06-15-2016 21:51
06-16-2016 09:24
06-16-2016 09:24
Ok - It finally started syncing again. I had to sign out of the fitbit app on both my phone and laptop, wait half hour, then signed back in on the phone. Going forward I will not leave the laptop app continously signed in and will periodically sign out from the phone app. I'm stressed. 😞
06-16-2016 14:40
06-16-2016 14:40
Mine seemed to be working beautifully, then fitbit had a mandatory update to all trackers. Since the update I've been having syncing issues on both my phone (Samsung Note 4) and laptop (Windows 10).
Any chance Fitbit can reverse the update or issue a fix for this massive problem?
(The update I'm referring to happened about two weeks ago.)
01-17-2017 06:04
01-17-2017 06:04
I have your exact same problem with exactly the same BQ phone. I have the blaze since March 2016 and for the life of me I have tried everything to make it sync. IT IS IMPOSSIBLE. Seriously considering selling the blaze and going to another brand
