05-29-2016 12:31
05-29-2016 12:31
Best Answer05-29-2016 12:44
05-29-2016 12:44
Best Answer05-29-2016 12:49
05-29-2016 12:49
Best Answer05-29-2016 12:54
05-29-2016 12:54
Best Answer05-29-2016 12:57
05-29-2016 12:57
06:10
08:23
05-30-2016
06:10
08:23
Good to see you around @Joybedford. I would maybe recommend trying to set up your tracker as a new device.
For this, go to your account section in the app and loof for the option that says "Set up a new device". Choose the Blaze and follow the on-screen instructions to complete the setup process. Just before setting it up as a new device, try to restart your tracker by pressing and holding the left and lower right buttons for 10-15 seconds until your tracker turns off and comes back on. Then set it up again and see if this helps.
Let me know how it goes!
