02-27-2016 22:13
02-27-2016 22:13
With the Blaze's versatility of being a removable module, I'd really like to see some third party developers get creative with an assortment of different bands/frames, or maybe even different types of housing for the blaze (like something that's just a clip if you didn't want to wear it on your wrist). Did anyone see/hear of anything like this? The only accessories I can find right now are the ones made by Fitbit, which surprises me. I'd really like to find a canvas band, or one that has a frame that is some color other than silver (like black or gold).
05-02-2016 07:10
05-02-2016 07:10
I haven't received the frame yet - supposed to arrive "May 2-17". It's from Vovotrade. I'll report on how well it does once I've received it. What company was yours from?
You should make sure that the pin has locked into the little holes in the frame. It can seem like it has, but not quite be set, and in that situation will pull out with a tug. That happened the first time I put the new band on, always on the lower side.
05-04-2016 15:23
05-04-2016 15:23
Rosegold frame from Toopoot.
05-04-2016 18:34
05-04-2016 18:34
05-05-2016 00:56
05-05-2016 00:56
05-05-2016 01:14
05-05-2016 01:14
05-05-2016 03:25
05-05-2016 03:25
05-06-2016 14:42
05-06-2016 14:42
i had to open a claim on Amazon to attempt to get my $12.00 back from TooPoot, for the purple mesh watchband that never arrived. too bad because i love all the colored ones, This seller kept emailing me and promisng "delivery or refund" but they never actually respond to what you say. I asked them first to resend the band and how about the matchign frame to make up for their holding my $$ for the last 6 weeks. they send the same email saying that they will make it right.
the kicker is that my order is still showing "ON TIME delivery"...sheesh, life is too short to keep running in circles after these people. hopefully a reputable prime seller will get me a blue frame and band in the next few months.
05-06-2016 15:52
05-06-2016 15:52
i just saw this on Amazon--both frame and leather band together for $19.97..must be a new seller, no reviews
05-07-2016 02:26
05-07-2016 02:26
05-11-2016 06:54
05-11-2016 06:54
OK, that Vovotrade frame arrived last night. The rose gold band matches perfectly in tone, but is glossy while the frame is matte. Otherwise they look good together - much better than a silver frame with a gold band. The band mated without any flaws, and is holding perfectly. I had to slightly stretch out the frame a bit before the Blaze could fit inside it, but that's now working well too. Pics attached.
05-13-2016 07:43
05-13-2016 07:43
I rec'd the Otiom blue mesh band and matching blue frame today. very nice tight fit--the blue is deep but not navy--the frame is MATTE. it came nicely boxed and i thought it was ready to go---i took it out of the box only to realize that only 1/2 of the band was attached to the frame!! (i was the person who spent hours in march trying to do this, succeeded in cutting my fingers--only to take to my jewelry store and the lady showed me with tweezers--now i am a pro). I was able to attach the other 1/2 of the band--twice because the first time i did it backwards and still be on time for work.
Anyway it is a nice looking band in a color i wanted, from a Prime seller. the color might scratch on the frame and magnet bar, i noticed this with my tweezers, but it is on the underside. i may put a coat of clear nail laquer on the magnet bar.. i would post a pic, but i can't figure that out either.
05-17-2016 17:30
05-17-2016 17:30
today I rec'd the "colorful" band which is like a rainbow--effect mesh with a rosegold base--also very pretty, i am waiting on the pink frame i ordered from china.
i have been wearking the royal blue since last Friday, doing heavy work--lifting garden stuff, plants mulch...not a scratch yet--(just the screen saver--i should buy these in 10 packs)
05-18-2016 07:25
05-18-2016 07:25
I bought a stainless band for the original frame it came with and picked up the following on Amazon in black stainless.
05-21-2016 10:59
05-21-2016 10:59
05-26-2016 20:58
05-26-2016 20:58
06-14-2016 17:19
06-14-2016 17:19
06-14-2016 20:45
06-14-2016 20:45
06-15-2016 01:56
06-15-2016 01:56
06-15-2016 06:47
06-15-2016 06:47
06-15-2016 06:56
06-15-2016 06:56
check pebble time. the pebble 2 comes out in nov.
people have complained (and posted pictures of the fitbit charge hr band bubbling up)
if you want to try a Blaze, i recommend buying from Costco.com, because they honor the return through the entire warranty period, not like fitbit's 45 days.
