03-23-2016 05:40 - edited 03-23-2016 05:43
Been lots of people questioning and looking, I just found, new today, a frame on amazon for $35 with free shipping, so $19 less than the only other seller on Amazong right now.
There is another one if you search Fitbit Blaze Housing.
There is one with the milanese loop attached already, pretty good deal to get the band and frame together already assembled for those who have had issues:
05-04-2016 06:47 - edited 05-04-2016 06:48
@racertempo Nope, no usuable tracking number. And actually Amazon still shows it is expected to be delivered in May. It just showed up in a little yellow padded evelope in my mailbox.
05-04-2016 07:26
05-04-2016 07:26
@Nocturnx wrote:@racertempo Nope, no usuable tracking number. And actually Amazon still shows it is expected to be delivered in May. It just showed up in a little yellow padded evelope in my mailbox.
I emailed them and they said it was scheduled for delivery May 11. Another ebay seller said something similar and it showed up that day they said. The ebay seller may have actually been the same as Toopoot as it was from the same area/district of China.
The problem with eBay is lots of sellers list as "USA" when it is really shipping from China to a distribution center in the US first, which is what happened in that other case for me.
05-04-2016 11:43
05-04-2016 11:43
@racertempo wrote:
@Hatman41 wrote:I bought my black bezel from user TOOPOOT on amazon http://www.amazon.com/Fitbit-Blaze-TOOPOOT-Stainless-Replace/dp/B01E38SSH6?ie=UTF8&psc=1&redirect=tr...
When did you order? I ordered the black and the gold frames from Toopoot and have yet to see anything, hoping that it is close behind your delivery.
I ordered mine on April 15.
05-04-2016 13:41 - edited 05-04-2016 13:41
@Fands wrote:i ordered mine on March 26(just the band in light purple)...it has not shown up yet, but it is"on the way" supposedly by May 6---then i can file a claim?
i wish that someone had the blue band and frame, i do like it. the only other seller that shows it, has 1 bad review saying that it does not fit the blaze at all
There are other sellers with a Blue frame, but you would have to buy the blue band separately.
05-04-2016 15:10
05-04-2016 15:10
I too ordered frames from toopoot on 04/15 and took 10 days to receive. There was no tracking. Like someone else mentioned, one of the buttons on the black frame screw was slipping out but not a big deal. I'm overall happy with them.
05-04-2016 15:16
05-04-2016 15:16
05-06-2016 19:11
05-06-2016 19:11
05-06-2016 19:12
05-06-2016 19:12
05-10-2016 05:39
05-10-2016 05:39
Yep, one of the balck rubber studs on my TooPoot frame have fallen out too and I can't get it back in. The 3 that are left hold it in fine though. Not sure I will bother to contact them over it, I'm still happy with it for $8.
05-10-2016 06:26
05-10-2016 06:26
I finally got my toopoot and the black frame is very nice. I also ordered the gold loop and gold frame, and unfortunately the frame I received was rose gold and did not match. After contacting them they wanted a picture of the package, then told me it was gold from the sku on the package. I told them their packager was making mistakes filling their pouches then, because the 2 clearly don't match.
You tell me which one this matches, and you can also see the loop is not a match to the frame:
#1
#2
05-10-2016 06:49
05-10-2016 06:49
I agree, the frame looks copper instead of gold.
05-10-2016 06:52
05-10-2016 06:52
@Nocturnx wrote:I agree, the frame looks copper instead of gold.
Yup, clearly not a matching gold like I ordered. They said it was the gold I ordered, and since I "was not pleased with my purchased" they would refund me 15%. I sent them these additional pictures and have not heard back. I also told them if they sent me the right gold frame that I ordered I would also purchase the blue frame and loop from them, but no response. Frustrating.......but it is not the end of the world for the price. The frames do fit the Blaze perfectly, for now 🙂
05-10-2016 15:46
05-10-2016 15:46
05-10-2016 15:50
05-10-2016 15:50
05-11-2016 08:00
05-11-2016 08:00
@Marimont wrote:
They will send you a new one. I just came across that same problem and I emailed them and asked for a replacement or a refund and sure enough they are sending me a new one.
Let me know how your new one turns out.
Toopoot told me that they would send a new one but it would be identical, so they offered a refund. I have not replied yet.
05-11-2016 08:48
05-11-2016 08:48
05-17-2016 15:10 - edited 05-17-2016 15:22
Just received the black replacement gram from toopoot! Def built better! I'm happy now. 😀
05-17-2016 17:47
05-17-2016 17:47
My black frame from them fits the unit perfectly, but the buttons are a little sticky.....but I am still satisfied for the price.
Toopoot did provide me a full refund for the gold not matching, so I look forward to seeing if your new "gold" is any different from the rose gold that was actually delivered.
05-18-2016 02:56
05-18-2016 02:56
05-18-2016 07:21
05-18-2016 07:21
I bought a stainless band for the original frame it came with and picked up the following on Amazon in black stainless.
