Tiles are not changing of color
In the new dashboard I wish the tile where you put your calories would change colors. Mine will go red if I'm way over but it doesn't change as far as in the zone or under goes. Also my sleep, and water never changes green even when I reach my goal.
4 REPLIES 4
It's great to see you around @SunsetRunner. Actually, the tiles don't change of color, is the icon of the tile that will congratulate you. If you are not seeing this change, I recommend double checking your goals. You can check this by doing the following from your Android Fitbit app:
1. Tap the account icon in the upper right corner
2. Search the information you want to change
3. Change your information if needed
4. Sync
Let me know the outcome. Woman Happy
On the old dash board it did change color. I liked that part better. Also
my sleep meter has been messing up the last 2 days
Thanks for the information @SunsetRunner, I took the liberty and searched for a request like this but didn't find any, I recommend taking a look at our feature suggestions board and share your opinion about the tiles. Now about the sleep, could you please be more specific about it? Is your information correct?
Hope to hear from you soon. Woman Happy
Well this happened today.
But yes one night I was up late and it said I was sleeping and I was
actually working on crafts. And the next night said I slept only 3 hours or
so and I actually slept most of the night.
