04-28-2018
21:52
11:43
FerdinandFitbit
04-28-2018
21:52
11:43
FerdinandFitbit
The Low battery screen on fit bit blaze should say at least the time. The screen that shows on the screen showing that it’s out of battery.
I mean at the end of the day this is a watch so you should at least say the time whenever I look to my watch to check the time I ought to see the time somewhere.
Terrible UX feature that should be fixed.
Best Answer04-30-2018 11:41
04-30-2018 11:41
Hi there @Low-battery-use. Great to see you in the Fitbit Community Forums! 🙂
Thanks a lot for your suggestion! I did some research and it seems that there is already a suggestion for low battery screens to show the time. However, it seems that this is not something that is currently planned to be implemented in the trackers. You can see the suggestion here.
Again, I really appreciate you taking the time to share this with us and if you have anything else to share with us, please feel free to do so!
