12-26-2016 07:42
12-26-2016 07:42
The display shows the time and it is three plus hours off. The time zone is set correctly on settings. How do I get the time to match on the watch to real time?
Best Answer12-26-2016 07:59
12-26-2016 07:59
Blaze will not syn. Time off by three hours. Tried to reset. Not working.
Best Answer12-26-2016 12:58
12-26-2016 12:58
In your app please check :
Settings/Advanced/ Time Zone / Set automatically
If this is off try turning it on and syncing.
Btw this flow is from the iOS app-
Best Answer12-26-2016 13:09
12-26-2016 13:09
hi, have exactly the same problem, have tried to set time zone to a different one and sync, but just keeps coming up with sync error. any ideas????
Best Answer12-26-2016 13:11
12-26-2016 13:11
oh and i am using the android version
Best Answer12-26-2016 14:00
12-26-2016 14:00
Mine is doing the same thing, and it will not sync to iPhone or iPad.
Best Answer12-26-2016 14:32
12-26-2016 14:32
ok, having checked through the forum topics, i have done the following:
1. shutdown and restarted and synced the blaze - no effect
2. restarted my samsung s5 and resynced the blaze - no effect
3. deleted the app and reloaded it, resynced the blaze - no effect
4. changed time zone as recommended resynced blaze - no effect
my blaze runs 2 hours behind london (GMT) and 5 days fast on the calender what am i doing wrong??
Best Answer12-27-2016 07:11
12-27-2016 07:11
It's on correct time zone and is turned. Still won't sync. Will not up date either. Tired of trying.
Best Answer12-27-2016 07:12
12-27-2016 07:12
Best Answer12-27-2016 11:38
12-27-2016 11:38
followed another thread that had the same issues, albeit loading the app onto my tablet and doing it that way (android tablet samsung galaxy tab) then went into account and replaced the tracker it asked for a code that was shown on the tracker i input, and then it synced. looks like i cracked it, lets see if it works now!1
