11-01-2017
02:27
05:16
AlejandraFitbit
11-01-2017
02:27
05:16
AlejandraFitbit
Hi, I have a Blaze and a Google Pixel (android) phone. Before the recent update I would have no problem tracking bike exercise every day. Now when I start the exercise on the Blaze it can not connect to the phone. I have them side by side, Fitbit app open on the phone and connected to the Blaze but it just wont find it on the Blaze. Sometimes it would connect and I can start the exercise but very soon it will lose connection and when I stop and check it has tracked just a few minutes max. So far I have tried:
Nothing has worked in terms of getting a stable connection for an exercise tracking between the phone and the Blaze. It all started after the update so I am pretty sure it has something to do with it. If anyone has had a similar issue and found a permanent fix please share. My hope is Fitbit are aware and will release new update to fix this as now this watch is completely useless for my needs.
Thanks!
11-01-2017 07:17 - edited 11-01-2017 07:17
I'm having a similar problem with an LG G6 from T-Mobile.
Blaze firmware 17.8.401.3
Android OS v7.0, security patch level 2017-10-01, kernel 3.18.31
Since Friday, my Blaze/app interaction has had the following symptoms:
All of these symptoms started on Friday. I don't know whether it was the latest Android update or Fitbit App update that caused them.
Remediation:
Note that the tracker works fine on its own, and when not connected to the App records correct distances (I assume because it knows my stride and isn't relying on spotty GPS data).
It seems that I can get about 12-15 months out of a Fitbit device before something breaks. Any chance this can get fixed or that the cycle of software problems can end?
11-03-2017 07:35
11-03-2017 07:35
I'm happy to report that Blaze update 17.8.402.1 seems to have fixed this issue for me.
That said, there's still an odd symptom. The Blaze seems to measure distance inconsistently. I took a walk this morning that my Blaze reported as 4.88 km but Google Maps (and prior experience) reports as 5.3 km. I live in Chicago, where streets are known distances apart. Major streets are consistently 800 meters apart in some places, so when I walk 800 meters and my blaze reports 740, I know there's a problem.
11-05-2017 05:20 - edited 11-05-2017 05:21
A warm welcome to the Community @batporio and @PunzunLtd it's great to see you around and to hear that the firmware update worked for you.
Thanks for troubleshooting this issue by yourselves. Keep in mind that in order to successfully connect your phone with your tracker, it needs to be compatible. Please check our list of compatible mobile devices to confirm that your phones are there.
If they are, I recommend checking that your trackers are updated, take a look at the My Blaze GPS is not working post and follow the instructions provided there, also verify that your stride length information is updated.
I hope this helps, let me know the outcome.
