03-02-2016
10:11
09:56
SilviaFitbit
03-02-2016
10:11
09:56
SilviaFitbit
My blaze battery is needing to be charged every other day. Not acceptable! I thought it was supposed to last 5 days.
Best Answer03-02-2016 13:46
03-02-2016 13:46
Hi, @Lynnwolfe! What type of features are you using? I got and charged mine on Friday and it's still on the same charge. The only feature I haven't been using is the alarm function. I also don't use call notification, only text, and I don't get a lot of those. However, I wouldn't think that would account for a multi-day difference of that much.
MakMak | Community Council
Best Answer03-02-2016 14:04
03-02-2016 14:04
Best Answer03-02-2016 14:18
03-02-2016 14:18
I too am on same charge since Friday - use all features except quick view.
Kelly | Oklahoma
Alta HR, Blaze, Flex 2, Charge 2, Charge, and Aria * IPhone 7+
03-02-2016 18:41
03-02-2016 18:41
09-07-2016 14:36
09-07-2016 14:36
Best Answer09-10-2016 06:21
09-10-2016 06:21
Hello everyone! @shisheen welcome to the Fitbit Community. The battery life of the tracker depends on your interaction with it I would like to share this tips to maximize the battery life of your tracker, if after trying this your battery is not lasting as expected, my advise is to contact our support team for assitance. They can take a look at your tracker's back-end information and provide you personalized assitance.
Let me know how it goes! 🙂
It is health that is real wealth and not pieces of silver and gold! Share your story!
Best Answer05-15-2017 16:17
05-15-2017 16:17
There a fit bit watch that runs on a battery like a regular wristwatch. One that you do not have to charge thank you
Best Answer05-16-2017 02:58
05-16-2017 02:58
I charge mine every 5-7 days. Depends on where I need to give it life support. The only thing I use it for:
Countdown timer if I am playing Grand Theft Auto Online or Dark Souls III or any game that I only want to spend a certain amount of time on.
All day sync is enabled on my phone. Which means periodically my Blaze will sync with my phone.
Nothing else is enabled on it such as call notifications, all that jazz. All that is off.
Takes me 90 minutes to charge it from it being "almost dead". Used to be 120 but I did that through my Xbox One as at the time there was no other place to plug the charger in.
