12-25-2016
08:27
09:56
12-25-2016
08:27
09:56
Brand new gift and I am not able to use because my computers....plural...and wall charger will not charge the fitbit. Customer service says they will send new charger cradle. As I have scrolled throught this site, I have seen numerous similar posts. How many faulty chargers did they send out?
Best Answer12-25-2016 13:37
12-25-2016 13:37
Same here, but I deleted the app on my phone, then installed it again and it worked straight away
Best Answer12-25-2016 14:05
12-25-2016 14:05
The problem is not the phone. The charging cradle will not connect to my Windows 10 laptop.
Best Answer12-25-2016 17:03
12-25-2016 17:03
When you say "will not connect", do you mean physically or that it doesn't recognise the Blaze?
The charging cradle is just meant to charge the Blaze, not sync with the computer if I recall correctly.
Best Answer12-25-2016 19:19
12-25-2016 19:19
will not connect in order to charge fitbit
Best Answer12-26-2016 08:39
12-26-2016 08:39
Hey @ctm4003 when setting up, did the app tell you that the battery is low?
That is the only way you will know if it is charging.
Best Answer12-26-2016 09:05
12-26-2016 09:05
Yes....charger will not connect to computer in order to charge Fitbit.
Best Answer12-26-2016 09:33
12-26-2016 09:33
I am having the same problem. Received the Blaze as a Christmas present. Started setting it up, and received a message that the battery was out of power. I have been unable to charge it on my Windows 10 computer. when I plug it in, the logo comes up briefly, so this suggests that "something" is happening. The charge level icon does not appear. I have tried multiple ports on my laptop.
It appears that this is a common problem. Does Fitbit have bad quality control? I am on endless hold waiting for a support person.
Best Answer12-26-2016 09:51
12-26-2016 09:51
I plugged mine in the wall and left if there overnight. It never showed it was charging. I added the app to my phone and the fitbit showed up as being fully charged. It seems to be working now. I cant tell you what happened and how it started working....
