11-10-2017 23:31
11-10-2017 23:31
I've checked the forum for resolutions but nothing has worked. My blaze volume control won't appear on screen and therefore wont work. It used to .. but then suddenly stopped.
I've cleaned both band/tracker gently. I've tried to set up as new blaze. I've shutdown blaze from the tracker settings screen.
Nothing.
I cannot reset it as those buttons are appearing to just not be working.
My blaze is only 4 months old and I'd say volume hasn't worked for the last 6weeks.
11-11-2017 01:03
11-11-2017 01:03
Awesome troubleshooting
Best Answer11-11-2017 06:54
11-11-2017 06:54
@LoveMissSxxx holding in the top right button should bring up music control. I would also check if Blaze 2 is connected to the phone if the phone is not iOS.
