What is the best way to track a spin class?
Hi there, I have been using the spinning activity mode when doing my spin classes and the heart rate seems pretty accurate however the calories burned seems quite low.  It is a high intensity 50 minute class with weights added in on tracks also.  Does anyone know a way around this?  I have checked to make sure my weight is accurate, worn it three fingers above wrist bone, etc.
Thanks!
25 REPLIES 25
If you feel the heart rate your Fitbit is recording is accurate, and you are confident that you have correctly entered your profile settings (gender, age, height, weight) then I think your calorie burn will be as accurate as it can be.  Many people over estimate the calories they burn from exercise.  An accurate heartrate will give you a very good estimation of effort.  Much better than anyone's guess of what you " ought" to have burned.
Hello @Melbell72 and @Julia_G It's great to have you here. 🙂  You can use several methods to track your exercise with your Blaze, I would recommend to test which of the following is the best for you:
SMARTTRACK
MULTISPORT
MANUALLY UPDATING THE EXERCISE
Let me know how it goes! 🙂
Retired ModeratorAngela | Community Moderator
It is health that is real wealth and not pieces of silver and gold! Share your story!
I know this is an old post, but I am having the same issue and wondered if anyone resolved it.  I do an hour spin class and feel like I am dying to find out I am only burning 300 calories.  I can do 30 minutes on the elliptical for the same calorie burn.  This just doesn't seem right to me.
Tighten the band a bit - the calorie burn will be based on the heart rate, and that reading can be inaccurate if the optical monitor isn't getting a good connection.
And whilst this is not particularly helpful, I've yet to get a properly accurate reading whilst on cycling sessions (regardless of tightness)
I've started doing some fairly intense watt bike sessions - 15 minutes (10k) - 272 calories in 15 minutes according to the bike, 232 according to my polar chest strap and 182 according to the fitbit - the latter is flat out wrong, but it didn't reliably track the heart rate, it was a gentle escalation from 100-175bpm, the blaze showed a peak of 185 at the wrong point in the session.
Dorketh- so you would agree that the Fitbit is inaccurate? I would think your chest strap would be most accurate. It's really frustrating.
I switched my band to one that fits me better and compared to a chest strap and they were pretty darn close. I also did the update at around the same time so not sure if that is relevant but made a big difference for me.
I find the eliptical exercise setup to match pretty closely to what I get off the eliptical machine so maybe try that?
Accuracy depends on usage of your arms - if you're making major use of the forearms, no optical tracker will be particularly accurate.
I tend to use the blaze if I'm running, where it is as accurate as a chest strap.
But on the watt bike, when rowing or on the ski erg it tends to be a bit hit and miss. So on those exercises I also wear my polar watch and chest strap.
@KBiz are you manually starting and using the Spinning mode function that's found on the Blaze, and not depending on the auto detect tracking feature?
As a matter of fact, I just found the Spining category tonight! But in the past, I was manually starting and stopping it using with the Workout or Bike categories.
Tell me more about the spinning category.  Where'd you find it at?  Is that working better for you?
I wear my Fitbit a bit higher on my arm during spin and I compare it to my Polar, h7heart rate strap which I use with the app as I like the colored heart rate zones to motivate me. It is pretty **ahem** accurate overall, usually w/in 15 calories of the strap.
I'm in the same boat. I work very hard and yet, I never exceed 400 calories for an hour of spin class. I think we tend to over-estimate how many calories we burn. I'm small (5'1'' / 105lbs) and 33. I think this is a pretty accurate estimate. My guy friend (28, 170lbs) burns close to 800 calories during the same class.
I spoke to my spin instructor who also wears a fitbit surge. She's the same height as me but has more muscle mass. She never goes over 500 calories.
Have tried many ways and the 3 fingrs above the wrist snd tight is best. However, I find fitbit to be inaccurate for spin in terms of the burn. I have a blaze and switched over from a polar w/HR monitor. Tested the two devices vs each other as had doubts re the accuracy of a wrist based monitor. Was very pleased w/Fitbit Blaze in general as I found the blaze to be fairly accurate for everything BUT spin -- where it's uually 50 calories off. I don't find that to be a big deal.
As I like polar's app on my cell  (I keep it on my handlebars) which lets me see my burn as I ride,  I I wear my HRM for spin as well as my Blaze so this is not a one time thing. I see it all the time and yes, I trust a chest HR monitor more than a wrist one. However, we're just talking maybe 50 calories and I find fitbit to be accurate overall. Me using the chest HRM during spin is a motivation thing (the pretty colors on the app motivate me to the next level and I like seeing in on my phone in fromt of me vs on my wrist as i ride). It is not an accuracy thing as the difference is not a big deal.
Great to see you here @jsherman. If you are having problems with your heart rate reading, I recommend checking this post, where you will be able to see some things that might be affecting your heart rate reading and some tips to improve this feature.
I hope this helps, see you around. Woman Happy
What is the best Fitbit device that will monitor spin classes for steps and calorie burn. The Charge HR is terrible for this and totally ineffective. I dont believe there is a spin app on this device. Do you have a device that does this more effectively that i can get?
@gymnut21 I would use the trackers multisport mode called spinning for the best calorie count. As for steps you might have to walk, since while spinning no steps are being taken.
Http://help.fitbit.com/?q=multisport
If you have a pocket.. put the tracker in your shorts..  after an hour spin I would register about 8 plus thousand steps.. I have a flex and a flex 2....
