06-21-2016 14:59
06-21-2016 14:59
When charging my Fitibt Blaze, the battery life indicator doesn't seem to change at all unless I disconnect it from the charger. I was charging it at low battery for about an hour or two and the battey indicator never changed. Once I disconnected it, the battery life jumped to the actual charged state. It use to never do this before.
06-21-2016 23:54
06-21-2016 23:54
08-10-2016 07:01
08-10-2016 07:01
A warm welcome to the Community @Pattyfatty. @Rich_Laue Thanks for stopping by and the recommendation.
I would like to know if you keep having problems charging your tracker, I you do, I recommend restarting the tracker and test it while charging it.
Let me know the outcome. ![]()
08-15-2017 13:21
08-15-2017 13:21
I see that you posted this over a year ago. My new Blaze (1 month old) is doing the same thing. I assume this means no fix in over a year : (
@Pattyfatty wrote:When charging my Fitibt Blaze, the battery life indicator doesn't seem to change at all unless I disconnect it from the charger. I was charging it at low battery for about an hour or two and the battey indicator never changed. Once I disconnected it, the battery life jumped to the actual charged state. It use to never do this before.
Best Answer12-25-2017 13:28
12-25-2017 13:28
My brand new Blaze (opened today) is doing the same thing. Very annoying having to keep taking it out of the charger to see how much more charging is required.
Best Answer12-25-2017 17:49
12-25-2017 17:49
Best Answer12-25-2017 21:19
12-25-2017 21:19
This is a known issue, even though the indicator doesn't move, the battery is charging. No need to remove it until it has charged for an hour, or sync the tracker the app will display the status.
