01-15-2017
05:25
19:51
DavideFitbit
01-15-2017
05:25
19:51
DavideFitbit
Will my Blaze still work if I turn off Bluetooth ? I'm a runner and want to know if it will still track while I'm running ? If I turn off Bluetooth
01-15-2017 08:57
01-15-2017 08:57
If you mean connected GPS the answer is no.
01-16-2017 05:27
01-16-2017 05:27
Welcome to the Community @Valcullen11 and @SunsetRunner thanks for stopping by.
If you want to use GPS, as mentioned, no it won't work. Now if you are not going to use GPS, you can go to run and then when you prefer you can sync your tracker without an inconvenience.
Catch you later.
