01-26-2016 08:00
01-26-2016 08:00
I like all the features and the price point of Blaze, but the reason I want to upgrade to a new tracker is to get away from using my phone to track my runs. It's a problem in the winter time as my iPhone gets too cold and then shuts down when I take it out to stop the recording. If the Blaze simply needs to connect with my phone by bluetooth and I don't need to be accessing any apps on the phone to start and stop the run, hopefully this will solve my problem.
01-26-2016 08:34
01-26-2016 08:34
@shoegal245 Hey there, welcome to the forums!
I can confirm this later on, but normally, you don't have to take your phone out to begin/end your Connected GPS exercise!
I'll get back to you once I'm 100% sure. PS- How cold does it get where you live, my goodness!
Best Answer01-26-2016 08:34
01-26-2016 08:34
Best Answer01-26-2016 11:44
01-26-2016 11:44
@shoegal245 wrote:It's a problem in the winter time as my iPhone gets too cold and then shuts down when I take it out to stop the recording.
@shoegal245 thats really weird, I've been snow skiing in temps down to 0 degrees Fahrenheit and pull out my iPhone 5s while riding up the chairlift to review my run. Never had it shutoff. I've seen a variety of phones shutoff if left out in the hot sun, but never from cold. How cold is it when you run?
Best Answer01-26-2016 14:47
01-26-2016 14:47
What i think @shoegal245 is describing is typical of a battery that is on its last legs, with internal damaged caused by excess heat.
It gets cold and the battery is unable to give the required amps to run the additional apps.
Best Answer01-26-2016 15:27
01-26-2016 15:27
@Rich_Laue wrote:What i think @shoegal245 is describing is typical of a battery that is on its last legs, with internal damaged caused by excess heat.
sure, like a bad car battery in the cold.
01-28-2016 08:00
01-28-2016 08:00
Best Answer01-28-2016 09:04 - edited 01-28-2016 09:15
Yes, I've been in Canada east of the rockies and it can be very cold.
Blaze specs:
Environmental Requirements
There are many reasons that most runners use Garmin, as they are best in class (water resistant, incredible depth of features, apps, etc).
This guy does an incredible job reviewing fitness devices, very detailed reviews. Checkout his latest buyers guide:
http://www.dcrainmaker.com/2015/11/winter-sports-gadget-recommendations.html
