Won't charge and hr is flashing like crazy
I bought my fit Bit blaze on October 21 2017 and now it will not charge..and the heart rate  part will not quite flashing like crazy at all . I try cleaning the charging pieces, and changed my plug in piece...
1 REPLY 1
It's great to have you here @Baywife! Thank you for the procedure that you've tried. I would like you to try restarting your tracker. Also, make sure you're properly charging it
Keep me posted.
