11-04-2017 16:26
11-04-2017 16:26
I just got a new fit bit blaze yesterday and charged it overnight when charging the display was on and working when i took it off the charge the display was off I’ve tried resetting and the other button arrangements what do I do
Best Answer11-05-2017 01:18
11-05-2017 01:18
Hi, @Selena_123, if your Blaze is charged, and you cannot get the screen to show even after trying to reset at least 3 times then I think you should either return the Blaze to where you bought it or get in touch with Fitbit Customer Support on contact.fitbit.com
