05-21-2017 15:02
05-21-2017 15:02
I bought my blaze 15 days ago and since past 5 days the battery performance is deteriorating constantly. yesterday the battery died in less than 24 hours. There's minimal usage.
Best Answer05-21-2017 17:39
05-21-2017 17:39
@chinmayc Have you tried restarting the Blaze? Sometimes that helps. If you have, and it still is not holding a charge, you may need to contact support so they can look into it further. http://help.fitbit.com/?cu=1
Kelly | Oklahoma
Alta HR, Blaze, Flex 2, Charge 2, Charge, and Aria * IPhone 7+
Best Answer05-22-2017 05:13
05-22-2017 05:13
It's great to welcome you @chinmayc and @Kmransom123 thanks for stopping by.
If you are having inconveniences with your Blaze battery life, I recommend taking a look at this post and follow the instructions provided there.
I hope this helps, let me know the outcome. ![]()
