06-04-2019 11:22 - last edited on 06-05-2019 19:31 by LiliyaFitbit
MY Blaze battery seems to last about 6 hours. I only have 1 light on the back lite up instead of 2. It is a solid green light instead of a blinking light. What may be wrong?
06-05-2019 19:29 - edited 06-05-2019 19:29
A warm welcome to the Community @kaymc66 !
Thank you for sharing that the battery on your Fitbit Blaze is draining faster than expected and there is only one solid Led light on the back of the tracker. If you haven't done so, I'd like you to restart your tracker as described in this help article: How do I restart my Fitbit device? This will refresh your tracker internally. I also recommend checking your heart rate setting and changing it to "Auto": Swipe to Settings on your tracker and find Heart Rate Tracking.
For complete tips to prevent battery drain, please see here.
Let me know how it goes!
Best Answer11-23-2019 02:11
11-23-2019 02:11
My fit bit has only one flashing green light. Can you advise what the issue is please?
Best Answer09-07-2020 20:36
09-07-2020 20:36
I did what was mentioned and it still doesn’t seem to help. Is there anything else I can do? Or is there any way to repair it?
I want to understand what is wrong with it.
