03-16-2016 20:07
03-16-2016 20:07
Best Answer03-16-2016 20:21
03-16-2016 20:21
I have had the blaze now for about 10 days and it is only lasting about 3 days before it needs to be recharged? Maybe mine is defective?![]()
Best Answer03-16-2016 20:36
03-16-2016 20:36
Same with me. Three days. If you reduce the brightness of the background light it will require less battery use and will help it last a little longer.
Best Answer03-17-2016 04:37
03-17-2016 04:37
Best Answer03-17-2016 05:06
03-17-2016 05:06
Good advice. Also, turn off all day syncing. You don't need it on.
Best Answer03-17-2016 08:32
03-17-2016 08:32
Please try doing a restart on the device by pressing and holding the Back and Select buttons (left and bottom right) until you see the Fitbit logo on the screen. This should take less than 10-15 seconds.
Restarting the fitbit sometimes gets rid of some kinks. Often times it helps the situation all together.
