02-26-2016 17:19
02-26-2016 17:19
04-13-2016 08:11
04-13-2016 08:11
same for me with my samsung galaxy. I enabled pop ups but there is no preview anywhere. Did anyone find a fix yet?
Best Answer04-13-2016 09:03
04-13-2016 09:03
04-13-2016 11:31
04-13-2016 11:31
Best Answer04-13-2016 11:34
04-13-2016 11:34
Can you tell me if this helped you read the messages or just to show you who is messaging you?
Best Answer04-14-2016 13:11
04-14-2016 13:11
That is controlled under display in the app settings.
Best Answer04-14-2016 16:50 - edited 04-17-2016 13:19
For messages installing Google messanger worked, I can now read the body even when I have multiple unread messages.
04-17-2016 11:31
04-17-2016 11:31
I am having the same issue with my Samsung S5. Really frustrating. If you figure it out please share! Thank you!
04-17-2016 15:59
04-17-2016 15:59
Best Answer04-17-2016 23:47
04-17-2016 23:47
@Kathybikes what is not with Verizon?
Best Answer05-04-2016 21:30
05-04-2016 21:30
It's cumbersome trying to set it up my new Blaze with my Galaxy S5. My hubby got it worked finally by enabling both notification on the phone messaging app AND on the Fitbit app as well. I agree with Rich_Laue that what is shown up on the phone locked screen will be shown on the Blaze. Moreover, if you are reading the text message on the phone, certainly there will be no pop-up on the Blaze because there will be no pop-up as the message is read as it received.
1. Enable Notification in Messaging app - follow other users' post (plently)
2. Enable Notifications in the Fitbit app:
Under the Dashboard, select Blaze -->General-->Call and Text Notifications-->Settings-->Text Notifications-->Enable Text notifications: turn it on.
Perhaps need to restart the phone after settings (i did this to get it to work).
Good luck!
Best Answer05-10-2016 11:57
05-10-2016 11:57
Thanks! This worked for my s4. 🙂
Best Answer05-17-2016 10:26 - edited 05-17-2016 10:29
@MakMak and @blueaugust29
This was super helpful! Thanks!
I had my notifications on but for some reason (on my iPhone 6S) I had to make sure that I turned on "Show in Notification Center" and now, all is right in the world 🙂
Best Answer05-18-2016 07:40
05-18-2016 07:40
not getting next messages on Blaze. I installed Handscent, uninstalled fit bit app from all my mobile devices, and reinstalled on my samsung galaxy 3. BT paired S3 but still not getting text on Blaze. I went trhough all the setting on Handscent but had not luck with texts showing up on Blaze. Any suggestions?
Best Answer05-18-2016 08:25
05-18-2016 08:25
Best Answer05-18-2016 08:39
05-18-2016 08:39
@evertdarryl - I have an iPhone so I'm not sure that the same solutions are going to work but I'm crossing my fingers!! Here are the three things that I did:
I hope this helps. Good luck!
Best Answer05-18-2016 08:56
05-18-2016 08:56
@evertdarryl, the only thing I can add to @Joanne619's answer is the Phone's Settings.
On Android go to Settings-Sounds And Notifacations then scroll down to Show on Lock Screen, then set to Show Content.
Best Answer06-16-2016 07:02
06-16-2016 07:02
Best Answer06-16-2016 09:33 - edited 06-16-2016 09:34
Hello @CUFELLA have you checked your settings as per the post above yours?
Which messaging app are you using? Do you get notifacations popup on the phones lock screen?
Basically weekday habe ypu checked or tried.
Best Answer06-16-2016 10:30
06-16-2016 10:30
I am using the default Samsung message app. I do get the preview notifications on my lock screen from sms as well as other apps. I checked permission and went as far as clearing data in the application manager.
Best Answer06-16-2016 12:00
06-16-2016 12:00
I'll assume the app is set up for notifacations, by any chance does tge Bkaze show up as connected in the phones BT screen?
