06-27-2017 12:10
06-27-2017 12:10
anyone else have this?
my blaze correctly logs the total distance hiked but the gps track
is incomplete. one instance has a plotted 5 miles missing but shows
consecutive mile makers either side of the gap. it's almost as if i had
stopped the recording then restated (which i hadn't). it's paired to an
iphone se and regularly syncs without issue. it also records shorter
trips without any problems.
05:10
09:05
06-29-2017
05:10
09:05
It's great to welcome you @SunsetRunner. If you are experiencing some inconveniences with the GPS connected feature, I recommend following the instructions provided in the My Blaze GPS is not working post. After these steps, please test your tracker.
Let me know the outcome. ![]()
Best Answer06-29-2017 09:18
06-29-2017 09:18
thanks for the tip, but that's not the problem mine has.
it does record "most" of the gps track, just lost a section
in the middle of the bike. i think it may have dropped the
connection to the phone. i shall be testing this weekend.
