01-14-2017 22:34
01-14-2017 22:34
blaze will only work when on charger. i was only able to setup my fitbit blaze when it was plugged into the craddle i held it onto the charger pins and set it up . but once i remove it from the charge cradle it doesnt work at all. when it is plugged in batter symbol says it is full.
01-07-2020 09:18
01-07-2020 09:18
Best Answer01-24-2020 04:51
01-24-2020 04:51
mine does same thing, it died in dec completely i put in on charger, says it’s fully charged black screen when i remove it, it’s 10 months old, no warrenty and i have followed all advice any other options?
Best Answer01-26-2020 18:11
01-26-2020 18:11
My Blaze stopped working about 3 weeks ago. I’ve had it since 2016. It would only come on while in charger and showing as fully charged.
I purchased a new Blaze today since mine was out of warranty. Another dud. I could only set it up while it was in the charger. Once it was set up and removed from charger it went dead. Such a faulty product to be so expensive. I will never purchase another Fitbit product if they cannot make this right.
Best Answer01-26-2020 18:48
01-26-2020 18:48
Best Answer01-27-2020 04:56
01-27-2020 04:56
09-26-2020 07:23
09-26-2020 07:23
Affects me too
