02-08-2018 13:53
02-08-2018 13:53
Brand new. At first when I turned my wrist the clock face lit up. Now (less than 24 hours later) the only way I can see the time is to tap twice. I want it to show clock when I turn my wrist to look at it.
Help. what do I do to fix it ??
Best Answer02-08-2018 14:03
02-08-2018 14:03
Have you check the settings on the Blaze to check if Quick view is still on?
02-08-2018 14:03
02-08-2018 14:03
02-08-2018 16:16
02-08-2018 16:16
thank you so much
Best Answer09-21-2018 00:16
09-21-2018 00:16
thanks you.
Best Answer05-23-2020 07:08
05-23-2020 07:08
Where is the quick view option
Best Answer05-27-2020 19:44
05-27-2020 19:44
Scroll to the "Settings" menu, "Quick View" is the first option.
Best Answer07-06-2020 07:12
07-06-2020 07:12
Under apps in settings there is no option for wake up on Charge 3. Does anyone know where that is located?
