01-19-2018 14:29
01-19-2018 14:29
I just purchased the eeeKit charger for my fitbit blaze ... It shows the correct charging wattage and Amps; however it does not show the UL Lab. label on it. Has anyone used this wall adapter on their blaze l .... is it ok to use. I called fitbit and they said they did not recommend any wall charger for the blaze!
Best Answer01-19-2018 19:55
01-19-2018 19:55
Probably not see this
See this thread for charging best practices. If you are not charging it correctly you could be damaging the battery
https://community.fitbit.com/t5/Charge/Fitbit-charge-battery-problems/m-p/1323307#M53291
Wendy | CA | Moto G6 Android
01-20-2018 02:20
01-20-2018 02:20
Thank you for your feedback. You have been most helpful!
