03-23-2019 11:06
03-23-2019 11:06
I wanted to use my blaze after a year so I put it on charge and it started showing full battery in 5 minutes ...but when I removed the watch from the charging dock..the watch does not start ..what do I do
03-23-2019 12:17
03-23-2019 12:17
If a restart won't help, you are probably out of luck as a lithium battery left discharged over any period of time can be permanently damaged.
03-23-2019 12:20
03-23-2019 12:20
how do I restart it and can the lithium battery be replaced?
03-23-2019 13:18
03-23-2019 13:18
Hi @tarekxx, it is nice to see you back! I'll be glad to help you out with your Blaze not turning on.
Thanks @SunsetRunner for jumping in! It is correct, in this case we would recommend trying a restart. You can find the steps on the article: How do I restart my Fitbit device?
The battery on Blaze can't be replaced, if you continue to have any issues with its battery, let us know and we'll be glad to continue assisting you.
03-23-2019 13:26
03-23-2019 13:26
I tried pushing the back and bottom right button for 15 seconds nothing happened
03-25-2019 09:46
03-25-2019 09:46
Hi @tarekxx , thanks for getting back and for trying the recommended troubleshooting!
I've reached our support team and they confirmed they are following up with you on this.
Please let me know if you have additional questions.
