new fit bit blaze won't turn on unless connected to charger with full batt
got a new fit bit blaze today and am trying to set it up. I've managed to do all that but it won't turn on unless connected to the charger. it's saying it has full battery but when I take it off charge it goes off and won't come back on unless I put it back in
7 REPLIES 7
Hi there @clairej81. Welcome to the Community Forums! 🙂
I'm sorry to hear that your tracker is not turning on. I'm glad you were able to set it up though!
I can recommend restarting it. For that, make sure to put it in the frame aligning the buttons on the frame with the buttons on the tracker. You can easily restart your tracker by pressing the left and lower right buttons for 10-12 seconds. This will make your tracker to reboot and it should come back on.
Try that out and let me know how it goes!
Ferdin | Community Moderator, Fitbit
Hi, I'm struggling with the same issue with my brand new blaze however the restarting method did not work. Do you have any other methods of fixing this ?
Hey @Ashley_lx! Great to see you in the Community Forums! 🙂
I'm sorry about your tracker 😕  Thanks for taking the time to follow the instructions I gave above.
If restarting your tracker didn't make it turn on, there's not much else that can be done. I would like to forward your case to the Support dept for them to take a closer look and they'll be happy to help you out with this!
Keep an eye on your inbox and let me know if you need more help!
Hi, I am having the same problem.  It won't turn on unless it is plugged in and resetting it has not helped.
I am having the same issue! Help!
Same problem. Seems ok when on charge but as soon as I take it off it dies. Tried to reset it and nothing happens.
I contacted support and they processed a warranty return.
They see it active on their end, including all of my many restarts.
I would recommend you chat with them and get a new one.
