01-04-2017 14:19 - last edited on 09-09-2020 10:13 by MatthewFitbit
My Charge2 is not recording my stairs.
09-05-2017 09:43 - edited 09-05-2017 09:44
Check the step count on the tracker both before and after climbing the stsirs. No steps counted, no stairs counted.
Moving the tracker up the arm makes sense if that is the arm on the hand rail.
09-06-2017 04:02
09-06-2017 04:02
09-06-2017 08:16
09-06-2017 08:16
Thanks Rich. actually it WILL count steps but not stairs at all times. But I thank everyone for your feedback. Am trying all suggestions and appreciate the info from this Community!
09-06-2017 08:17
09-06-2017 08:17
Thanks Kelly!! Awesome info!!
09-06-2017 09:32
09-06-2017 09:32
I've been up 7 flights of stairs today, but only 3 have been counted. I go up the same way every time, 1st time this has happened!
09-06-2017 12:49
09-06-2017 12:49
See, I am NOT alone on this. Fitbit needs to upgrade maybe!! Also twice this week, my setting on my weight using Pounds has changed on it's on to milligrams!! Please fix these glitches. the stairs issue is especially annoying and it is NOT the user!!!
09-06-2017 13:01
09-06-2017 13:01
09-06-2017 13:30
09-06-2017 13:30
09-06-2017 14:41
09-06-2017 14:41
Thanks..That is EXACTLY where I wear it. Read all the instructions and all the suggestions and EVERYTHING works awesome except for the stair issue but according to Fitbit, that's most likely due to my stairs being "only"10 feet long. WHATEVER..
I love this Fitbit.!!!
09-06-2017 14:43
09-06-2017 14:43
all other readings are awesome. It will not slip as long as you snug up your wrist band. If it's moving you might consider making it tighter. Hope this helps.
09-06-2017 14:58
09-06-2017 14:58
09-06-2017 23:46
09-06-2017 23:46
I wear my FB C2 in the same place all the time, first time it happened!
12-31-2017 17:00
12-31-2017 17:00
It's not solved! Why do the moderators here always write "solved" on post that are obviously not solved. Fact is my charge used to count stairs and now it does not. It has nothing to do with swinging arms or going slow. There is a problem with the product and you don't know how to fix it.
12-31-2017 17:08
12-31-2017 17:08
01-01-2018 02:54
01-01-2018 02:54
Stair counts are affected by the weather. Changes in air pressure cause increments in the count. Don't get too perturbed by it....the stair count doesn't get included in any calculations of calorie burn or activity.
01-01-2018 05:08
01-01-2018 05:08
01-01-2018 09:48
01-01-2018 09:48
01-01-2018 09:53
01-01-2018 09:53
01-01-2018 14:37
01-01-2018 14:37
01-01-2018 18:10
01-01-2018 18:10
