10-25-2017 06:14 - last edited on 09-09-2020 09:26 by MatthewFitbit
Had my charge2 for a week and it won’t track the deep sleep rem and the stages it to track when I’m sleeping. What do I do to fix it.
01-02-2018 08:22
01-02-2018 08:22
@Flicker24, what are your options other than returning it as Fitbit suggested? If it doesn't work for you, it won't be of much value to you.
01-02-2018 09:06
01-02-2018 09:06
I see a few options @Flicker24
Some have reported that
- turning heart rate to on has helped.
- changing sleep mode to sensitive
- set the tracker up as an replacement unit
- switch tracker a with the other person for a night.
01-12-2018 04:32
01-12-2018 04:32
How can this issue be marked as solved?
it is clearly still an issue for many that CHARGE 2 DOES NOT display sleep stages for all users. I’ve had multiple email discussions with Fitbit support teams and to date, my husbands works and mine does not ~ reference issue #23000798
01-12-2018 08:47
01-12-2018 08:47
01-12-2018 11:08
01-12-2018 11:08
Yep, I agree. Mine isnt work either.
01-18-2018 09:21
01-18-2018 09:21
Loving my charge 2 in general but count me as one more to the list of people having problems with its sleep tracking. I've had it since around Christmas and I've only received detailed sleep stages 4 times on intermittent days. All the other nights have only resulted in the simplified sleep report. I'm going to try some of the fixes mentioned here but I'm not holding out much hope based on what I've read!
01-18-2018 11:16
01-18-2018 11:16
02-12-2018 08:05
02-12-2018 08:05
I have had my charge 2 for nearly two weeks. It tracked my sleep stages on one night, 6 nights ago. I do everything you suggest. Could it be anything to do with the heart-beat itself?
02-12-2018 08:13
02-12-2018 08:13
02-12-2018 08:24
02-12-2018 08:24
02-12-2018 09:17
02-12-2018 09:17
02-12-2018 18:03
02-12-2018 18:03
Hi Jmcm46,
Might want to try out a few of the workarounds as suggested in the Fitbit Charge 2 tracking sleep like a flex thread where several owners (including myself) have experienced sleep stage monitoring issues. None of the workarounds are satisfactory, but if you're not having much joy in getting sleep stage monitoring working as it's supposed to, might as well try out the workarounds to see if one or all of them will kick the device back into functioning as it's supposed to.
Ionic and Alta HR owners are also experiencing similar sleep stage monitoring issues.
The problem stems from how the algorithms determine sleep stages based on what Fitbit calls heart rate variability (HRV), the inter-beat data which is a sub-set of the raw heart rate. Until Fitbit releases a software / firmware up-date, afraid we're going to have to live with buggy software and be their beta testers.
02-13-2018 00:06
02-13-2018 00:06
02-13-2018 11:52
02-13-2018 11:52
02-13-2018 13:33
02-13-2018 13:33
02-13-2018 13:35
02-13-2018 13:35
02-14-2018 00:19
02-14-2018 00:19
02-14-2018 22:56
02-14-2018 22:56
I hav3 exactly the same problem ! It works if my husband wears it but not it I wear it !
02-15-2018 17:08
02-15-2018 17:08
I use sleep tracking from August to January and got sleep stages regularly until January. I have tried everything suggested about how to wear the Charge 2 and have done the reset. Nothing has helped. I now get just simplified sleep.
02-19-2018 13:13
02-19-2018 13:13
