12-02-2016 19:47 - last edited on 09-09-2020 10:26 by MatthewFitbit
For the last week my charge 2has refused to sync. The app is set to always connected and all day sync. I have reset the tracker several times in the charger. I have turned my phone on and off, turned the Bluetooth on and off, logged out and back into the app, force stopped the app and reopened. Nothing has worked. I get no error message so I'm assuming it can "see" the tracker.
What else can I do?
03-18-2018 14:19
03-18-2018 14:19
can somebody please help me with getting my fitbit charge 2 to sync
03-18-2018 21:20
03-18-2018 21:20
a couple of questions for you @vmaryc.
What type of device do you sync through?
Has yoiryCjarge 2 been setup to a fitbitFaccount yet and does not show the setup message?
03-19-2018 02:47
03-19-2018 02:47
03-19-2018 02:55
03-19-2018 02:55
03-19-2018 11:02
03-19-2018 11:02
No need to delete it from the dashboard .Do an add tracker than choose the replace option.
This way if the setup fails the tracker is still connected to your account. Do a search. you will find many posts of. "I deleted my tracker and now I can't get it setup"
Consider yourself lucky that you where able to set it up.
03-19-2018 12:18
03-19-2018 12:18
04-08-2018 10:28
04-08-2018 10:28
Where can i find these instructions that werr posted by stilldreamin? Sounds like it might be exactly what i need to fix my sync priblem with my charge 2
04-08-2018 11:06 - last edited on 04-09-2018 04:04 by AlvaroFitbit
Put your watch in the charger. While charging, hold the side button down until the screen goes black and then it will light back up. That’s how you reset it. Then you can take it off the charger. Heidi (-:
Moderator edit: removed personal information
04-08-2018 14:12
04-08-2018 14:12
@dsmyth57 The easiest why is to first tag @Stilldreamin or go to their post above and tap on their name. This will take you to a page with a list of their posts. It should then be easy to find.
04-08-2018 16:14
04-08-2018 16:14
05-09-2018 10:42
05-09-2018 10:42
Hey folks! How are you today?
If you have syncing issues with your Charge 2, I would like to recommend you the following:
- Make sure that you have a compatible device
- Make sure that you have the latest version of the Fitbit app installed on your iOS and Android devices
- Reboot the Bluetooth on your phones
- Reboot your phones
- Log out/log in to your Fitbit account
- On the Bluetooth settings, tap on "forget device" and then pair it again
- Try to use a computer that meets the requirements to sync your Charge 2. To get assistance with this part, take a look at this help article: why won't my Fitbit device sync.
Let me know if that works!
05-09-2018 11:17
05-09-2018 11:17
05-24-2018 16:40
05-24-2018 16:40
Hi Rich..If I do an "add tracker" then use the "reset" option will this wipe out all the information currently stored? I haven't had a problem with my Charge 2 in over a year...but today, it refuses to fully sync...
05-24-2018 20:14
05-24-2018 20:14
05-25-2018 01:38
05-25-2018 01:38
The tracker will send it's data dieting a sync, this is the only way to remove data from the tracker.
There isn't a reset procedure it is simply a restart and doesn't reset any data.
05-25-2018 04:27
05-25-2018 04:27
05-27-2018 17:46
05-27-2018 17:46
My fit bit Charge 2 won’t sync with iPhones.
05-27-2018 19:08
05-27-2018 19:08
How many iPhone's have you tried to sync with @Feandfo16? Are you making sure that only the one is turned on if the rest are nearby?
05-28-2018 11:10
05-28-2018 11:10
06-01-2018 09:39 - last edited on 07-10-2018 08:27 by HeydyF
I have followed all the instructions and it finds the tracker. I put the dispayed number and is spins for 5 minutes and fails.
I want my money back. HR 2 it bloody useless!
Moderator edit: Removed caps
