12-02-2016 19:47 - last edited on 09-09-2020 10:26 by MatthewFitbit
For the last week my charge 2has refused to sync. The app is set to always connected and all day sync. I have reset the tracker several times in the charger. I have turned my phone on and off, turned the Bluetooth on and off, logged out and back into the app, force stopped the app and reopened. Nothing has worked. I get no error message so I'm assuming it can "see" the tracker.
What else can I do?
08-23-2017 08:25
08-23-2017 08:25
Mine is working now Thanks
08-23-2017 11:57
08-23-2017 11:57
08-24-2017 06:12
08-24-2017 06:12
I was having the same problem of not syncing, tried your fix, and it worked. Thank you!
08-26-2017 08:13
08-26-2017 08:13
Mine is doing the same thing. When I removed it from bluetooth it wont see it anymore... any suggestions? I have iPhone6 iOS system.
08-26-2017 10:36
08-26-2017 10:36
I'm having the same problem. I've tried removing the app and the installing again but without success. I can't even complete the installation because of some location permission that I apparently have to allow but we I can't because it says I have an screen overlay detected that I can't seem to disable. So frustrating. I may just buy another tracker as I've tried for days to fix this, but to no avail.
08-27-2017 15:37
08-27-2017 15:37
08-27-2017 17:14
08-27-2017 17:14
Turn OFF wifi
KEEP Bluetooth on
SYNC
Sometimes I have to pull the screen down to start the sync. Watch for the blue line to enter from the left, indicating sync has started.
Good luck!
08-27-2017 17:16
08-27-2017 17:16
Keep the Bluetooth on, deactivate your wifi. If you deactivate the Bluetooth then the devices can't communicate. Once that is done, sync.
Good luck.
08-27-2017 19:04
08-27-2017 19:04
08-27-2017 21:15
08-27-2017 21:15
Since the last update the app is crashing and now Bluetooth cannot find my tracker. I have done everything for the last two weeks to fix it. Why would the app keep closing after 5 seconds? I have cleared out all unused apps and ram.
I hope someone can help!!!
Thankyou
Heather
08-27-2017 21:32
08-27-2017 21:32
thank you.... it helped to reset it on the charger, thanks
08-31-2017 14:56
08-31-2017 14:56
In all seriousness... if your tracker is still under warrantee return it NOW. Mine started doing that and I spent an hour working with the Fitbit tech to get it to work. Was able to get it to connect and then a few weeks later it did it again and after spending another 1+hrs on a chat with a rep (well 2 actually since the first one just diconnected from me when he got annoyed that it still did not work and I insisted that it should) I was told ... well gee sorry, your 3rd fitbit has also crapped out, it is a few months older than 1year so your warrantee is over and you should buy another one.. we will send you a 20% discount coupon if you want.
08-31-2017 22:01
08-31-2017 22:01
That is really rubbish! I cannot believe they would not accept it under warranty even though it was a few months out. I was silly and purchased mine through Ebay but it was brand new in the box. Seeing they are on sale here, I will just purchase another one. But I wonder if I should just get the Garmin?
09-01-2017 23:19
09-01-2017 23:19
I was having the same problem and following these steps for me worked straight away! Thanks!
09-03-2017 06:13
09-03-2017 06:13
09-03-2017 14:06
09-03-2017 14:06
09-03-2017 14:09
09-03-2017 14:09
09-03-2017 14:41
09-03-2017 14:41
Yes very happy! Sometimes its worth the extra for tech support and warrantys
09-07-2017 12:48
09-07-2017 12:48
I have been trying to pair my Charge 2 with my iPhone 6S for a few weeks without success. A couple of times it seemed to work then stopped. This is very frustrating and disappointing.
09-07-2017 19:17
09-07-2017 19:17
