12-02-2016 19:47 - last edited on 09-09-2020 10:26 by MatthewFitbit
For the last week my charge 2has refused to sync. The app is set to always connected and all day sync. I have reset the tracker several times in the charger. I have turned my phone on and off, turned the Bluetooth on and off, logged out and back into the app, force stopped the app and reopened. Nothing has worked. I get no error message so I'm assuming it can "see" the tracker.
What else can I do?
09-08-2017 00:25
09-08-2017 00:25
It is very frustrating! I tried all the troubleshooting options with no luck. I contacted Fitbit support two weeks ago and they are aware of the issues and are working on them. So I have left it for now
09-11-2017 13:40
09-11-2017 13:40
09-15-2017 18:50
09-15-2017 18:50
Why is my phone not syncing with the charge 2
09-15-2017 19:07
09-15-2017 19:07
If you are using an iPhone and have an iPad turn the iPad off.
I found that the when I am trying to pair the Fitbit band, regardless which one, with the app on the iPhone the Bluetooth signal from the iPad will interfere with the Bluetooth signal from the iPhone. Once the iPad is turned off the problem of paring/syncing with the iPhone will disappear.
09-26-2017 07:11
09-26-2017 07:11
Just upgraded my iPhone to iOS 11 and the Charge 2 won't notify when messages and calls come to the phone. Notifications is on. I have tried the restart procedure with no success. App is current. Suggestions to get the Fitbit to receive notifications? Thank you.
09-26-2017 07:43
09-26-2017 07:43
09-29-2017 22:09
09-29-2017 22:09
I recently received a Charge 2 to replace my old HR. Setup went great and everything synched. Unfortunately it hasn't done a sync since then even though I have tried all the steps listed. I have Samsung 7 and Windows 10 on Surface Tablet. Can't get a sync on either device. Help please.
10-06-2017 07:58
10-06-2017 07:58
Seriously? This is the "fix"? And how often do I need to do this? Not good. Not at all!
10-06-2017 08:15 - edited 10-06-2017 08:24
NEW problem: just tried re-pairing with my phone, and the phone is unable to communicate with the Charge 2. What fresh hell is this???
My wife and I are really sick of our Charge 2 fitbits, and how they randomly disconnect and lose sync. We have different phones, both Android, and with both the sync connection works MOST of the time. But for some reason, at random times the connection drops and the sync stops. Presently, it is mine that has stopped.
I have tried:
- unpairing the Charge 2 from my phone and re-pairing it
- uninstalling the Fitbit app on my phone and reinstalling it
- restarting my phone
- stopping and starting bluetooth
- restarting my Charge 2
- updating my Charge 2
NOTHING works this time.
If this happened once a year, it would not be so bad, but it happens at random intervals every few weeks to BOTH our phones. I'm about ready to sell these things on Ebay and get a Forerunner. Not happy at all.
By the way: this is our second set of Fitbit trackers. We had Charge HR trackers, and they had lots of issues, so Fitbit was kind enough to allow us to return them for full refunds.
10-06-2017 08:16
10-06-2017 08:16
10-06-2017 08:23
10-06-2017 08:23
10-06-2017 09:04
10-06-2017 09:04
Chatting with support now. We fixed the issue with my phone and tracker, but the idea that any other bluetooth device synced to my phone could cause me to have to jump through so many hoops to reestablish connectivity... on random occasions... is very disturbing. And my wife doesn't use any other bluetooth devices with her phone, yet her problem crops up more often than my own.
10-08-2017 18:51
10-08-2017 18:51
I have an iPhone and my Fitbit charge 2 wasn't syncing. I just shut my phone off and restarted it and that worked!
10-08-2017 21:41
10-08-2017 21:41
@Revjeff, im not sure if the "Fix" yoir referring to is the turn off the Bluetooth of one device, or move it at least 30 feet away, to sync through another device. This is not a fix but a workaround to tue limitation of Bluetooth, not Fi5bit. Have you ever tried to play two phones thro7gh one Bluetooth speaker at the same time?
Normally i would say f9r a sync issue
Restart tracker
Restart phone
Remove tracker from phones bluetooth
Clear apps cache, android
Set tracker up as a replacement, i only remember doing this once.
10-16-2017 08:28
10-16-2017 08:28
I have removed my fitbit charge 2 from the Bluetooth settings, and it cannot find my fitbit charge 2 on the Bluetooth settings.
10-16-2017 08:39
10-16-2017 08:39
Do you have an iPhone? If so, shut down/turn off your phone and then turn it back on and wait a few minutes. This is what worked for me.
10-16-2017 11:26
10-16-2017 11:26
Same problem here 😕
10-18-2017 09:18
10-18-2017 09:18
I have tried that a couple times, but will try once more!
10-24-2017 20:45
10-24-2017 20:45
I followed the directions given as the solution, as I am having the same issue with my Fitbit charge 2 and now my phone is not finding any Bluetooth signal from my Fitbit. Is there a trick to this I am missing?
10-24-2017 21:13
10-24-2017 21:13
@emtgunter and @JennyB01 are you using the Fitbit app to sync the tracker?
Just like ehen you first setup your tracker. It was setup through the app, not thd phones bluetooth.
Once removed from thr phones bluetooth, open the Fitbit app, it most likrly will sync.
