How to show battery level on Charge 2
A coworker of mine who has Charge 2 just like mine, showed me today where he cycles through the heartrate, run, stopwatch, etc. etc. and he now had a battery level indication. He said with the lastest software update it showed up on his. I just did an update on mine and I still don't have the battery level indicator on my Charge 2. Any ideas on what is going on here? Thanks.
28 REPLIES 28
Thanks, I was missing the battery.
I just got my Charge 2 August 11th , I have updat 22.22.55.2 but I still don't have a battery indicator. Getting very frustrated.
@met422, have you gone into the app device settings, under Menu, and enabled the "Battery" setting? If so, did you sync the tracker after making that change?
@met422 we also have an extensive help center.
How do I customize the menus on my Charge 2?
Learn how to add, delete, and re-order the menus that appear on your Fitbit Charge 2.
@WendyB wrote:
Open fitbit app, Tap account, tap charge 2, tap menu items, put a check mark in Battery
It will need to sync before it takes place
My profession of 40 years is writing technical instructions. Experts often lose sight of what beginners don't know. The simple additions of "tap menu icon" before "Tap account", and of "scroll down to menu items" after "tap charge 2" would have saved me (and multiple other community members who also couldn't find the battery display option in the app) some considerable frustration.
thank you for being persistent and sharing the knowledge
Perfect, just what I needed to know!
Thanks,
Captain BobStarl
When I open the fit bit app there is no "account" to tap on to... Where do you suggest I find "account"?
The account tap
