07-12-2018 16:43 - last edited on 09-08-2020 18:22 by MatthewFitbit
I used to be able to get texts on my Fitbit but not anymore. Does anyone know how to fix that? Thank you.
08-06-2018 18:14
08-06-2018 18:14
Marre,
I am having a similar problem with my Charge 2. Just recently I am still receiving text notifications, but not the message. All it says is "new message" and the person that sent it. It used to scroll what the text was. I reviewed everything in your first message and everything appears fine, then I did the 3 steps in this message and it has not fixed the problem. How can I resolve this so that I start seeing the message again? I did verify in the Fitbit app under text that it is checked to show message and sender.
Miki
08-16-2018 07:52
08-16-2018 07:52
I am having a similar problem with my Charge 2 that fay711 did in July 2018.. Just recently I am still receiving text notifications, but not the message. All it says is "new message" and the person that sent it. It used to scroll what the text was. I reviewed everything in your resolutions that Marre posted under this topic and everything appears fine, then I did the 3 steps in the next resolution message and it has not fixed the problem. How can I resolve this so that I start seeing the message again? I did verify in the Fitbit app under text that it is checked to show message and sender.
Miki
01-18-2019 09:22
01-18-2019 09:22
MarreFitbit - Thanks so much for your info. Forgetting and pairing the Device again solved the problem! Thanks for taking the time to provide great guidance!
