08-15-2018 13:16 - last edited on 09-08-2020 18:22 by MatthewFitbit
My fit bit charge 2 was working very well until one day I woke up and it started to change the screen itself with no reason until the battery discharged, so I decided to charge it and do a manual reset but without succes.
Can anybody help me?
Thank you
08-15-2018 17:13
08-15-2018 17:13
Mine is doing that too. I updated it. Charged it, shut it off, hooked it up to my lap top. Nothing is working! I took a video with my phone to post but it won't let me post a video.
08-15-2018 18:29
08-15-2018 18:29
Mine is doing it as well. It’s updated as well as far as what was supposed to be.
08-16-2018 02:25 - edited 08-18-2018 00:56
I have the same issue. Restarting my device only gives a short-term solution as at any point it might start doing it again and render the device useless until all battery life is gone.
Update: After spending some time with customer support and sending them a video of the situation they sent a replacement my way. Yes I was the lucky one (relatively - still unlucky for this issue) to be under warranty.
08-16-2018 05:32
08-16-2018 05:32
Yes! Same situation, and there is no fix. Talked to agent last night. There is no fix for problem being reset doesn’t resolve issue. If you bought it and are under 365 days you might be under warranty. Otherwise you can be given discount for new purchase. Which doesn’t fix problem for future users.
08-16-2018 20:59
08-16-2018 20:59
08-17-2018 05:21
08-17-2018 05:21
Yeah! That’s the sucky part no warranty no fix.
01-25-2020 10:22
01-25-2020 10:22
Mine has started doing this too, it works one minute then goes crazy changing the screens repeatedly. Is there any fix?? I’m out of warranty as I’ve had mine for a few years.
12-22-2020 10:16
12-22-2020 10:16
My Fitbit decides it wants to go crazy and screens turns on and off by its self. Have you been able to fix it?
12-22-2020 11:11
12-22-2020 11:11
@Msdrea928 It's good that the community is growing!
Let me help you with this. You don't mention any troubleshoots so I suggest you restart your tracker by doing the following:
Let me know how it goes.
