Search instead for
What is the difference between Charge 2 and charge 2 Special edition
SOLVED
Accepted Solution
1 ACCEPTED SOLUTION
Accepted Solutions
@Jacharo  The difference is in the color of the band and tracker.  The functionality of the tracker is the same for each.
Kelly | Oklahoma
Alta HR, Blaze, Flex 2, Charge 2, Charge, and Aria * IPhone 7+
Accepted Solution
Kelly | Oklahoma
Accepted Solution
Is the metal band sides that makes the special edition more expensive 30 bucks?
Accepted Solution
Thanks
Accepted Solution
Why 30 dollars difference if are the same, as well the colors?
Accepted Solution
Zzz dupe Zzzz
RICH | NJ, USA
Ionic, Surge, blaze, Alta HR, Flex 2, Charge 2, Charge, Charge HR, One, Zip, Ulta, Force - GALAXY S8,
Accepted Solution
Possibly yes the side colors might.. For one thing, there will be less made.. Lower production means higher price to manufacture. I'm not sure about the color but it might also require a special process to put on. This is the case with the Blaze
RICH | NJ, USA
Accepted Solution
I keep my products a long time (comparatively) so was curious about this as well, if I am investing now is it worth my investment.  This was the information I gathered as part of my research "The features are identical between both versions. The difference is just the colors. The Special Edition versions undergo an additional process during their manufacture to apply the gold or gunmetal finish."
Hope that helps - Wanda Smiley Very Happy
Accepted Solution
 agree with you
Accepted Solution
